350hp out of chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2006, 02:32 PM
Hey guys Im now looking into what engine to get for my rx7!! I really leaning toward a mid 80s 350!!! I was going to use the Whole z28 drivetrain(5speed)! I just wanted to know was it possible to get 350 motor hp out of the engine without bumping the compression!(untouched block)
thanks
Old 10-15-2006, 05:20 PM
Wiki Edits: 31
no bolt on except forced induction is going to give you 1 hp per cube. compression makes HP. you could get smaller chamber heads for bumping the compression a point, or a thinner head gasket, but then the rings would likely fail from the newfound compression. really, 9.5:1 with a mild cam, intake and headders might get 350 HP.
Old 10-15-2006, 05:25 PM
poncho62's Avatar
Wiki Edits: 5
A good set of aftermarket heads will get you there...with the right carb, intake and cam of course. 70s-80s small blocks had lousey heads, generally.
Old 10-15-2006, 05:35 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Well, it depends on the year of the z28...
If its an 80's z, I'd consider bumping the compression, but its not a huge deal at the 350 hp level. You certainly don't need 9.5:1. With modern heads, 350hp is as easy as breathing.
218/224 cam on a 110LSA, 8.7 to 9:1 under vortec heads, performer intake, small tube headers, done. 350 easy. I've done that combo a few times. The vortecs let you get away with less cam. Less cam is better suited to moderate CR. I'll agree, at an intake duration of 218, 9:1 is a bit better suited, and you'll still be able to run cheap gas if you tune it carefully, but any more than that will just add headaches, expensive gas, and only get about 10 more hp.
Old 10-17-2006, 09:51 AM
Wow that easy to get 350hp My car I had to buy all kinds of things to get around that! I was going to look for an 80s because I dont want fuel injected! I was going to have the following
votec heads
apr heads studs
headers
670 carb
exhaust
intake manifold
cam
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 06:03 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
engine cooling specs for 350 4 bolt chevy downunder Introduce Yourself 2 10-02-2004 10:41 PM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
