350sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2003, 12:23 AM
350sbc
i put a new eldbrock intake and changed out the pionts to a hei off a 87 z28 and replace the valve covers with some chrome ones and had to set the timing after this i had it fired but it like it was burning oil off the side but i looked closer and smoke was coming from the breather as well. but it ran fine, then i changed nothing and put on a set of headers and now the damn thing will not start and i thought that some how it may have thrown off the timing so i turn the dis but had no luck what am i to do.
Old 09-14-2003, 01:23 AM
Check to see if its getting fire to the plugs.
If not you may have just had the HEI module go out....When they go they just go.
Old 09-14-2003, 11:21 PM
Doesn't the 87 Camaro use a computer to control the timing?
Old 09-15-2003, 02:24 PM
yes but the car was completly converted out of the computer era for dragging purposes.
Old 09-15-2003, 02:49 PM
muddyone's Avatar
I would have to agree with Blown72Camero,I had this once after pulling a distributor to replace intake manifold gaskets.Put the distributor back in and tightened everything up and nothing.Tried everything under the sun.Turned out to be the damn module.Quite frustrating but let me tell you, this will never happen again.
Old 09-16-2003, 03:30 PM
i repalced the mod will an accel but it still will not fire it wants to but it will not, it acts as if the firing is off but i had it running before i put in new headers and i never pulled out the dis.
Old 09-16-2003, 09:34 PM
E.T. divided by $ spent= Speed
Did you acidently mismatch the plug wires when ya put them back on after the headers???Is it burpin out the carb??
Old 09-17-2003, 03:04 AM
lord's Avatar
is it flooded? Once I flooded my car so bad the shop I took it to had to pull out the plugs so the cylinders could dry out. I originally blew a modulator.
