350sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2004, 12:52 PM
jrm123180's Avatar
A Learning Hobbist
350sbc
i'm replacing the main and rod bearings on my '79 350sbc 4bolt.
My question is, i dipped the bearings in oil before I put them in, is that sufficient or do I need a special lube on there like I do on my cam.
Also, do i need or should I use some kind of thread locker on my main bolts and also my rod bolts...or for that matter, any other bolts in my motor?
thanks once again,
steve
Old 08-09-2004, 02:41 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Keep the backs of the bearing dry to prevent spinning them. Lock tight compound isn't nessacery but if if you feel frogy... jump. Wipe a liitle oil on the bearing surface and prelube before atart up.
