350sbc 4bblwith Holley carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2012, 10:29 AM
Hey guys I think I need to fine tune this engine ....and I need help ...car starts no problem and runs good at idle ... But when I attempt rev it pops in carb and stutters to rev up or accept fuel ...what's going on here
Old 05-23-2012, 04:34 PM
Last journal entry: owner of heads emotionally attached
maybe
Had a afb years ago did the same was vacuum leak because the butterfly bushings in secondaries was worn and thus a vacuum leak unless its a new carb look there
Old 05-23-2012, 04:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Does the accelerator pump deliver a shot of fuel the instant the throttle is opened?
Old 05-23-2012, 05:33 PM
Not a new carb but intake was removed ....never took carb off intake just took apart as one ...cobalt ...yes to your question or to me it is from what I can see ...like maybe a lil too much I'm thinking I guess I should back down on idle throttle and play with air/fuel mix .....question I got is ...what piece of diagnostic equipment can I buy to properly diagnose
Old 05-23-2012, 05:40 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I suppose a wide band air/fuel meter might help diagnose and tune it, but the cost is high.
Before going that route, I would try more or less accelerator pump shot to see if that showed me anything. You will need to use different accelerator cams and possibly shooters to tune the accelerator pump circuit. More on that HERE.
If that didn't cure it, I would be sure the advance curve and the initial timing is enough for the engine- too little initial advance (retarded timing) will cause the engine to pop back through the carb.
What is the carb number? What do the plugs look like?
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
I.D Holley Carb crussell85 Engine 6 07-16-2011 02:00 PM
What size carb? 350sbc zz430 crate engine joe brienza Engine 10 04-10-2010 11:59 PM
holley carb not right old fords Engine 12 12-12-2009 05:48 PM
holley carb jeyrl Engine 1 01-27-2006 09:56 AM
