350TH question????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2006, 08:55 AM
350TH question?????
I have plugged the vacuum hose going to my modulater on my 350TH in my drag only car and must shift it manually. My question is, when I stop the car and put the trans in 3rd gear, manually, then drive off slowly, the car seems like it is still in 1st gear, ie- high revs going slow. I thought it would be very sluggish since it was in 3rd gear. I can stop the car, put trans in 1st, drive off slowly and shift it to 2nd then to 3rd, then stop again. Leaving the trans in 3rd, when I start off, it still seems like it is in 1st gear. What do ya'll think ? Is this right?
Old 10-18-2006, 09:08 AM
poncho62's Avatar
Wiki Edits: 5
The modulator only determines the shift points. To make it totally manual, you need to modify or replace the valve body. You are not gaining a thing by plugging up the vacuum line.....just making it more difficult to drive.
Old 10-18-2006, 09:16 AM
Jmark's Avatar
Yep,,,,what Poncho said!!
Mark
Old 10-18-2006, 09:24 AM
astroracer's Avatar
Here is what TCI has to say about vacuum modulators...
http://www.tciauto.com/Products/Comp...modulators.asp
Like Poncho said, you need a few more mods to make your trans fully "manual". I hope you haven't hurt it by plugging the vacuum modulator...
Putting the shifter in 3rd gear, while sitting still, will do nothing. The trans only sees line pressure when the vehicle is moving. The line pressure needs to be at a certain point before the trans will up-shift to 2nd or 3rd. This is why it starts out in first and then up-shifts to 2nd. The trans will automatically downshift as you slow down so it is always in "first gear" when you start rolling.
Mark
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
