350to a 383 compression difference
If i swap all my parts from my rotating 350 assembly and put in a 383 rotating assembly with my same 041 heads.Will i change the compression drastically, again using the same cc volume pistons ,head gasket etc but for a 383,and instead of a XE268, put in a XS274s,or even a XS282S, current compression 10:1 in the 350.
With all variables kept the same, just changing from 3.48" stroke to the 3.75" stroke will result in the 383 having .5-.6 more compression due to the larger swept volume(more cubic inches) being squeezed into the same size space at TDC. Your 10-1 will become 10.6-1.
Compression ratio calculator here at www.wallaceracing.com on the calculators page |
So, since you have to change pistons or rods anyway, the best choice is to use a "D"-shaped cup piston w/the correct volume to keep the CR where you want it. |
350to a383
I was thinking a 3.75 scat 9000 crank, scat 6 inch pro comp rods floating pins, 7/16 cap screws, clearanced for strokers, but I have no clue as to the type of piston i neeed,the cam will be a Comp solid flat tappet grind # 12-677-4,or12-676-4.
Asfar as the pistons any recommendatrions the block is .060 397010 with 041 heads fully ported 2.02-1.60 254cfm@.600 lift flow bench tested,before last rebuild,due I go forged ,hypereutectic,?, I will not be adding any power adders,but I do intend on using the cams full potential any suggestions D shape ,2 valve releifs ,4valve releifs I'm not very good in this dept. I dont want the compression higher than 10.50-1 --11.00-1 we have 94 octane here plus the availabability of additives makes getting 100 octane no problem to put in the tank. Any help would give me peace of mind fellas.Thanks everyone |
350to383
Thanks alot you sure are an eye opener.
Do be sure to use a CD or piece of plexiglass, plastic, etc. w/a hole in it for adding water and allowing air to escape.
If you don't use a cover like that, the surface tension will allow you to add a LOT more water than the chamber's actual size. You wouldn't think it would be all that much, but it is. |
350 to 383
Thanks a bunch Cobalt.
| sb350 no compression | underthegallows | Engine | 19 | 04-13-2010 12:35 PM |
| 350 vs 383 build for performance | Biscuit6447 | Hotrodding Basics | 20 | 03-05-2010 08:42 AM |
| 350 to 383 "Camparison" | ssmonty | Engine | 5 | 05-17-2007 07:17 PM |
| Most compression for Pump gas? | NWayne | Engine | 19 | 03-09-2007 01:46 AM |
| Best blocks for 383 chevy, there is a difference | roys63 | Engine | 20 | 03-20-2003 08:38 AM |
