351? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2012, 06:37 PM
351?
I have a motor that a friend gave me, he says its a 302 but the manifold clearly says 5.8. Obviously its no 5.0, the distributor gear measures 1 1/4, and the valve covers are 6 bolt. There is a stamp in the
lifter valley that says 351, Do I have my hands on a Windsor?
Old 07-01-2012, 08:42 AM
icsmannn's Avatar
You need to write down the numbers stamped on the outer face of one of the heads. I'm not a SBF guy but this is how Chevy does it. Then you can research those stamped numbers, on an Engine Chart website....(I Googled the question and found this website Help - decode engine block, Original? - Ford Mustang Forums - According to one of the sites listed, it appears Ford didn't always stamp their blocks and tranny's like Chevy. News to ME! LOL!
Old 07-01-2012, 10:21 PM
If it says 5.8 and 351, sure sounds like a 351W to me. Measure a pushrod, the 302 pushrods are something like 6.25" and the 351W should be around 8.150" or 8.182" depending on the rockers.
The numbers stamped on the passenger side of the block around the starter will help you figure out what year it is, too.
Old 07-03-2012, 09:07 PM
e9ae-6015-aa-13. Here are the casting numbers. Any help is appreciated
Old 07-03-2012, 09:58 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I can't seem to recall how to do an "Advanced Search", but I KNOW there is a previous thread here on HR.com that had a couple of really nice pictures that made it extremely easy (foolproof) to spot the taller deck height on a 351W.
It had to do with the difference between the "china wall" and the distributor mounting bolt.
I *did* find this using Google Images:
which is also a good visual indication of the difference.
Old 07-03-2012, 10:09 PM
66GMC's Avatar
How To Identify Classic Ford V-8 Engines
302:
351W:
The reinforcing ribs from the "China Wall" to the timing cover are a dead give-away as well.
Old 07-03-2012, 10:49 PM
huge help, thank you!!
Old 07-07-2012, 09:22 AM
Even the pistons have 351w stamped in them
Old 07-07-2012, 06:25 PM
66GMC's Avatar
Lots of Ford engines have a 4.00" bore.
Obviously even Henry had to go to great lengths in order to avoid confusion.
Old 07-08-2012, 08:57 PM
TexasDave's Avatar
Gear Head
Yep, that's a 351
Your 351W came out of a 1989 Ford Crown Victoria.
The break down is as follows,
E = 1980
9 = 198(9)
A = Crown Victoria
E = Engine
Old 07-08-2012, 09:08 PM
66GMC's Avatar
Originally Posted by TexasDave View Post
Yep, that's a 351
E = 1980
9 = 198(9)
A = Crown Victoria
E = Engine
You are correct in decoding the "E9AE" part ... and it might have come out of an 89 Crown Vic ... but that same cylinder block casting number could also likely be found in a newer-model Econoline van.
(These numbers are cast-in, rather than "stamped in", correct?)
Old 07-09-2012, 08:38 PM
Yes cast. Only downside, a timing cover bolt broke off. After soaking it for a few days in penetrating oil my extractor broke too! Major headache, and really don't want to change hole size
351 Modified vs. 351 windsor vs. 351 cleavland ? Blackbob Engine 78 01-27-2013 05:15 AM
351 windsor swaped with 351 modifed fordboy210 Engine 6 09-02-2008 11:22 PM
351 Clevor vs. 351 Cleveland fearsomefairmont Engine 43 05-04-2008 06:37 PM
351 cleveland 351 windsor whatwouldscoobydo Engine 24 12-26-2004 09:55 PM
351?? serg18 Engine 3 05-04-2004 12:09 PM
