351 blowby problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2011, 10:28 AM
351 blowby problem
Ok I have a 1978 f100 with 351 w out of a 85 in it with A 4 speed. Trans in the floor the problem is I'm having some serious blow by in it all the cylinders have compression But the blow by is getting worse I know it could be the timing or the rings I know it could be allot of things but can any on bounce ideas to help my bf and I figure this out...
Old 08-02-2011, 10:52 AM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
How do you know that all cylinders have blow-by? What tests have you done? what are your compression numbers in the cylinders? Do you have oil in your intake? need a little bit more info to help you out.
Old 08-02-2011, 11:03 AM
Camaro820's Avatar
ok so i saw this on TV. if you dont have a breather in your valve covers, make on. drill a hole big enough to install a breather on your valve cover (side doesnt matter) and then drill a hole in your header, closer down towards the collector, thread it and thread in a tailpiece brass fitting or something, then attach a rubber hose from the breather on the valve cover to the brass fitting. that should solve your blow by if the rings aren't damaged.
Old 08-02-2011, 11:04 AM
I'm not saying they do Im saying they all have really good compression I know it has blow by because the people we bought it from had a cap on it that had a breather valve on it so we tried to put a new cap on it with out the valve and as soon as I accelerated it blew the seal and oil all over the engine something's not right with the engine I'm trying to help my boyfriend figure this out but he's the gear head I'm the body gal lol
Old 08-02-2011, 11:11 AM
I'm. Thinking it's the rings were trying to solve the problem the truck has been acting differently (losing hp acting like it's 20 below when you 1st start it up when it's 95 with a heat index of like 105 lol just acting weird
Old 08-02-2011, 11:37 AM
Where do you live, I'll come and take a look.LOL
Old 08-02-2011, 11:51 AM
chevykid90's Avatar
so what your saying happened is that you put a cap on your valve cover breather hole? and when you hit the gas it blew the cap off your valve cover and blew oil everywhere? just wanted to make sure i read that post right..
Old 08-02-2011, 03:16 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Your thread title "OK, any suggestions" doesn't describe your problem or work well in the search function, changed it.
Semper Fi
Blowby Crispies 123pugsy Engine 3 04-27-2011 05:21 PM
Oil blowby/oil burning waltnardo Engine 7 03-24-2008 10:43 PM
Ford C3 Blowby ?? Theresa Shank Transmission - Rearend 3 09-26-2006 06:18 PM
blowby ram440 Engine 2 08-05-2006 04:07 PM
Blowby Problem Arrowhead Engine 6 09-23-2005 06:16 AM
