351 C in place of 351M - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 09-30-2005, 02:20 AM
aka Duke of URL
Originally Posted by dmorris1200
I just figured I'd add this. There has been multiple mention of big block vs. small block. This quote was taken from a site that covers most Ford engines pretty well.
To the best of my knowledge the bore spacing and head bolt pattern designates Windsors and Clevelands as 'small blocks'. Ford's other engine families do not share that same characteristic. Below is a link to where I got that particular quote from.
I think the FORD Small Block/Big Block argument is no longer valid as it once was. Back when... ...the small block was the 221/260/289 and the big block was the FE Series. Somewheres along the line, the 385 Series became known as the Big Block. There are now so many variations, that one series cannot be identified as such no longer.
Look at GM. How many engine variations did they have once you get away from the SBC/BBC?
  #32 (permalink)
Old 09-30-2005, 05:13 AM
dmorris1200's Avatar
doesn't play well with others
True. It's easy to forget GM had Buick engines, Caddy engines, Olds engines, and Pontiac engines that were all different from one another. I always tell people it isn't all that hard you just need to learn some basics. The beauty of today compared to twenty years ago is the availability of information for free at the touch of a button over the internet. A simple search engine can uncover a wealth of info. As far as the BB/SB dilemma that has been a mystery for years for most people. I think I read somewhere that it wasn't even Ford that originally assigned the labels to there engines but builders/machinists that took the classifications from GM who started the whole BB/SB thing. Don't know personally but the cylinder bore spacing and head bolt pattern as mentioned on that web site makes sense to me. I remember years ago people arguing whether or not the Pontiac 400 was a small block or big block. Some felt 'BB' cause of it's cubic inches, others said it was neither cause Pontiac never had a SB or BB. I guess 'big block/small block' is less relevant than just making sure you have the right part match-up for any given application.
BUILT FORD TOUGH
  #33 (permalink)
Old 09-30-2005, 09:52 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by xntrik
Also.... way back in # 3 I said that (quote) "GENERALLY SPEAKING the C is considered a small block....because of the way stuff bolts on."
because he was wanting an easy way to determine what would fit in the existing hole.
Duke and 1200,
Thanks, that is some great information. I never saw one of those blocks.
The M and C cranks and rods are not interchangeable, are they?
x
  #34 (permalink)
Old 09-30-2005, 10:56 AM
x
The 351M and 400 both have 3.000" main journals, the 351C has 2.749" journals. The link I provided before shows the measurements for the Cleveland engines. It worth the time clicking on the links to all the different engine families and reading through, some good info.
BUILT FORD TOUGH
  #35 (permalink)
Old 09-30-2005, 03:55 PM
swap 351M for 351C
Now basically I am rather lost in this thread, but I have the feeling that the engine will go into my car. However, I need a new tranny with a C4 bellhousing pattern and a new distributor. Am I correct on this assumtion?
Thanks
Chris
  #36 (permalink)
Old 09-30-2005, 09:17 PM
xntrik's Avatar
you got mail
Thanks
Chris
you got mail
351 Modified vs. 351 windsor vs. 351 cleavland ? Blackbob Engine 78 01-27-2013 04:15 AM
parts for 351 windsor Doug Renton Engine 5 09-13-2009 02:18 PM
Ford 351 Windsor Teardown & Rebuild 101 nightrain_rod Engine 10 07-20-2008 01:57 AM
351 Clevor vs. 351 Cleveland fearsomefairmont Engine 43 05-04-2008 05:37 PM
351 Ho? oldschoolrods Engine 17 03-05-2005 03:48 PM
