Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 351 Cleavland valve seals
Old 10-28-2002, 03:08 PM
slider slider is offline
I like that rope trick Best Mechanic. Having had the engine take off with the air pressure is exciting to say the least. At best you won't bleed when you hit your noggin on the hood so you can get a beer down quick. Last time I looked KD made the valve spring compressors for most everything, even some universals.
