Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated 11/07/08
#1
Alittle1
169 edits
#2
Crashfarmer
161 edits
#3
Powerrodsmike
125 edits
#4
Techinspector1
112 edits
#5
Oldguy829
85 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 07-17-2005, 02:38 PM
Cleveland 50 Cleveland 50 is offline
351 Cleveland in 50 Ford
Anybody have any experience or ideas on what I will need to install a cleveland in my 50 ford. I want to stick with the stock frame and use a C4 or C6. What oil pan will give me clearence over the crossmember? What about engine and trans mounts? What do you think?
Old 07-17-2005, 06:26 PM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
 KULTULZ's barnstar
re: 351 Cleveland in 50 Ford
I could have sworn I replied to this post earlier today.
There is also a post missing (I cannot find) concerning a gentleman that wants to know how to wire an accessory tach to a 2005 F150.
If you still need help on the CLV, let me know.
...gotta stop buying that cheap vermouth...
Old 07-17-2005, 07:12 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Yup One of those Moderator's
 OneMoreTime's barnstar
Wiki Edits: 3
H,mmmm
I do not think the engine or trans mounts will give any trouble..might need a speck of fabricating but nothing that cannot be done..
You may need to get a truck oil pan and pickup as I think you will need a rear sump pan..
Other than that this should be a fairly easy swap..at least as far as swaps go..
OMT
If it don't work it ain't pretty!!!!
Old 07-17-2005, 09:59 PM
Nightfire's Avatar
Nightfire Nightfire is offline
Young & Idealistic
 Nightfire's barnstar
Wiki Edits: 4
Kultuz the tach question is now in electrical.
As for the '50 Ford, glad to see people putting FORDS in a FORD. Sounds like a great project, I love '49-51 Shoebox Fords!
Mike
Old 07-17-2005, 11:47 PM
KULTULZ's Avatar
aka Duke of URL
 KULTULZ's barnstar
Mike
OK...THANX!
I remember distinctly replying to this post earlier and referring him to Gearheads Products (for the mount kits) and his replying to the post...
Time to update my medication I guess.
Yes, it is a relief to not hear someone say SBC. The 351C will sit the same way a 302/351W will sit as both styles have the same engine mount pads on their skirts.
________________________________________
Mercury-Edsel-Lincoln
-Divisions of CONTINENTAL
-MEL Engine Forum-
Old 07-18-2005, 12:53 PM
Cleveland in a 50
Kultulz- Yes you did reply, and thanks. Does anyone know if the pan from a 351M or a 400 will fit? Also, what years of truck do I need to look at?
Hmmm---Vermouth. Isn't that the stuff I walk by on the way to the Gin?
Kerry
Old 07-18-2005, 01:22 PM
KULTULZ's Avatar
aka Duke of URL
 KULTULZ's barnstar
Yes, they will interchange. The 351C has a front sump. If you need a rear sump, it will be on a mid-seventies/early eighties pickup 4X4 351M/400. You will also need the pickup tube and the retainer on the main cap that holds the pickup tube.
Old 07-18-2005, 10:17 PM
Pony's Avatar
Pony Pony is offline
I put a Clevland in my 53 Ford sedan and the engine compartment has enough room. The biggest problem is the drivers side exhaust. Theres not a lot of room there. Although I sub framed mine and use a Chrysler K-member & torsion bar front end, The steering box is close to where the stock unit was located. I can't get headers to fit but the stock manifolds do fit and flow just fine for the average street engine. The front firewall radiator opening had to be enlarged to fit a larger (wider) radiator and everything else was standard engine swap stuff. There are some pics in my gallery of thr 53.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "351 Cleveland in 50 Ford"
Ford Ranger V8 Conversion nightrain_rod Hotrodders' Lounge 52 03-04-2007 10:10 AM
headers for a 50 ford gottaluvchevelles Hotrodding Basics 2 10-19-2004 04:37 AM
Ford 351 37fordslantback Engine 3 04-25-2004 01:57 PM
my 50 Ford coupe ebiosca General Rodding Tech 3 03-05-2003 10:30 AM
Ford Straight 6 swap to a 302 or 351 BillyBob1950 Engine 5 01-18-2003 02:42 PM
