#16
The Cleveland bottom end is better for high rpms, with it's small crank journals, The head design, although it was a good idea with the canted valve and big ports, I think you'd be better off with a windsor. The windsor crank is much bigger and beefier. With forced induction the port size is not so much of an issue. Many cleveland guys fill the bottoms of the ports anyway, and find they run better throughout the rpm range anyway.
IIRC, the intake ports on a 4 v cleveland are bigger than a stock BB chevy. Do you need that? I am slowly building a 4v closed chamber cleveland for my wife's 70 mustang, (that was the stock motor, and this is a restoration), and have enough stuff to build either a windsor or closed chamber 4V cleveland for my 69 mustang, I still haven't decided yet what exactly I want to do with that car. I'm leaning towards the windsor motor for that one, because I've had good luck with them in the past. Later, mikey Register now (free) or login to remove ads
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| Thread Tools | Search this Thread |
| Similar Threads for: "351 Cleveland, good choice?" | ||||
| 351 windsor swaped with 351 modifed | fordboy210 | Engine | 6 | 09-02-2008 10:22 PM |
| Ford 351 Windsor Teardown & Rebuild 101 | nightrain_rod | Engine | 10 | 07-20-2008 01:57 AM |
| 351 Clevor vs. 351 Cleveland | fearsomefairmont | Engine | 43 | 05-04-2008 05:37 PM |
| re T-Bird 351 swap. | problem solvers | Engine | 5 | 09-15-2006 04:27 AM |
| can i destroke a 351 w with a 302 or stroke a 302 with a 351w? | jims84gt350 | Engine | 5 | 04-02-2006 01:04 PM |
