Flush the fuel lines out. IF you have good fuel being delivered to the carb, I'd bet the carb is still a dead player. You probably will need 2 gallons of fresh gas with 4 bottles of carb cleaner in it to flush the system, and it will take a while to get the gas slime out. |
I have filled the carb with fuel from a squirt bottle, while tank was empty gas line unhooked at carb, carb is a simple one to rebuild cleaned good blew out all passeges with a compresser, seem like a vac leak somewhere, car ran an drove when parked 5 years ago.some reason it wont run at all without choke all the way shut, then when it does run, it runs like its missing and popping thru carb and tail pipes.could be timing, took me a while to get dizzy broke lose must be a ford thing
Checked tdc with my thumb over the plug hole, rotor pointed straight at number one plug wire on dizzy cap. Could it be the ignition box below solinoid on fender well, what would the box being bad do, not crank at all, or run bad when cranked. Any ideas would really help. thanks Wormy
Check the pressure coming from the fuel pump, when they sit the rubber diaphragm in the pump dries out and they don't work too good.
But would it not run with the carb bowl filled from the bottle, gas line un hooked at carb. Can check fuel pressure with my vac gauge, should be 5 to 8 pounds about i guess any more ideas every little bit helps thanks Wormy
Check the vacuum advance, and the points breaker plate for wear, or looseness. My 1973 351C 4V with factory dual points had this same problem, and this was what it took to fix it.
G'day Mr.Wormy,
It does sound like an ignition problem to me. OK, you've rebuilt the dizzy ?, check to make sure everything is where it should be, then once you're happy check the dwell angle. Use a dwell meter or Timing light with dwell check function. Setting the points gap will only get you in the ball park as far as dwell goes, you need to set it at 26-30 degrees, recommended for 351C. Too far outside this dwell angle either way and you'll get a gutless dog of a motor. Are you using a new or known good working coil ?. Run full 12 Volts to the coil until you get it running then switch it back to normal voltage through the ballast resistor. If this fails then I think you need to start from scratch just like any troubleshooter would. Perhaps ask a buddy to help who has got some skills in the area. Quite often a fresh pair of eyes can nail the problem. Hope you get it sorted........Barry. |
I am now leaning towards replacing the stock distributor with MSD. Stephen Last edited by carsavvycook; 06-10-2008 at 12:32 AM. Reason: additional wording |
Thanks everyone the problem sounds like a dizzy one for sure, will check this morning its just that you have to run choke all the way shut to get it to run at all, that has me thinking its a bigtime vac leak could be chasing my tail on the vac theory, i will report back as soon as i have eliminated dizzy and coil trouble Thanks, Wormy
You really won't want to hear this but I had the same problems on my 73 Mustang. I rebuilt the carb, replaced the fuel pump, wires, plugs, points and it still didn't run any better. The car ran good before I parked it but it just sat too long. What happened to my car was a valve hung open and condensation built up in a cylinder and rusted the bore, valve and seat. I tried everything to get it to run better but it just wouldn't. I finally threw a compression tester on it and found a dead cylinder, I ended up swapping in a different engine. Hopefully you don't have the same issue and is something simple like a blown intake gasket or bad dizzy.
onebadmerc the car sat for 5 years, but it was in a inclosed garage heated and cooled, dosent mean it couldnt be a bad valve or valves just seems like a timing or vac issue, if it ran better i could diagnose it better, vac gauge jumps from 5 to 10, and it sounds like its missing on 2 or 3 cyls, that would make it have low vac Thanks for all your thoughts somtimes you need a sounding board Thanks again Wormy
| parts for 351 windsor | Doug Renton | Engine | 5 | 09-13-2009 02:18 PM |
| Ford 351 Windsor Teardown & Rebuild 101 | nightrain_rod | Engine | 10 | 07-20-2008 01:57 AM |
| 351 Clevor vs. 351 Cleveland | fearsomefairmont | Engine | 43 | 05-04-2008 05:37 PM |
| re T-Bird 351 swap. | problem solvers | Engine | 5 | 09-15-2006 04:27 AM |
| can i destroke a 351 w with a 302 or stroke a 302 with a 351w? | jims84gt350 | Engine | 5 | 04-02-2006 01:04 PM |
