| View Poll Results: Which one? | |||
| Straight Cleveland |
2 | 33.33% |
| Cleveland/Windsor Mongrel |
2 | 33.33% |
| Other |
2 | 33.33% |
| Voters: 6. You may not vote on this poll | |||
LinkBack | Thread Tools |
The stock Cleveland block will be cheaper, how much money you got.
Some junkyard scouting/Buy @ Sell luck might score you a good used block, the oiling mod can be done with a drill, a tap and a drilled plug for the restrictor...no rocket science involved. Haven't seen to many cracked blocks but I have seen a few cracked factory forged cranks. Usually because they have been beat on...severely. Maybe some of our Aussie friends could send us Cleveland fans in the Northern hemisphere some good used castings by boat, they are getting scarce up here. Preferably some HO versions please.
Outlawed tunes from outlawed pipes |
While I agree about oiling mods for extended high rpms, I don't agree with the cracking. I've got 6 Clevelands and none are cracked and have has at least that many more in the past,no cracks. You may be confusing the early 400s that had that problem with the Cleveland, although they appear similar a 400/351M is not a Cleveland in most Ford guys mind.
I've been entertaining the same build,I have also been told by a couple different people that oiling is a problem on the 351 Clev bottom end,I was also told that 4v heads flowed to much,but threw more research I found by increasing the displacement,stroke,It makes for one sweet package,wish I could say first hand.
As a follow up,
Do you know where I could buy the oil restrictor kit for a cleveland, and what is a good source for a block? I have found them online (DSC motorsports or ebay, around $200-300, worn standard bore) but shipping is rather expensive. Also, is it possible to stroke a 351 cleveland? I have heard that a 3.85 in stroke crank, 5.955 in rods, and a 1.3 in compression height piston makes 393 ci, and since I am beefing up the bottom end I figure why not get more cubic inches. You guys truly are a wealth of info. Thanks again. |
Hey the Clevelands are awsome if you have any ?'s whatso-ever relating to the "C" and some that are not go here
http://www.network54.com/Hide/Forum/119419 It is a forum dedicated to the Cleveland |
Instead of stroking the Cleveland, just get a 400 block, stroke it to 427. use it with your 4V Cleveland head.
http://hotrodders.com/gallery/showph...cat=500&page=1 Last edited by 400C53F100; 03-31-2004 at 07:06 PM. |
Aren't the newer 5.8/Windsors roller? They must be lighter anyway,and you get to keep the small bell housing and mounts if that matters. I did ride in a 1/2 ton 400 truck with 4v C heads and a 280 comp cam and it was impressive for the money he had in it.
I would use a late model 5.8 roller block. An earlier block can be modified by adapting the inexpensive roller kit available from Ford Racing. Then you can use all the cheap HP cams from the 5.0.
The cleveland heads will bolt on if you drill all the water passage holes. The main problem is a shortage of intake manifolds. The last time I checked there was one small company making an intake for the combination of Cleveland heads on a Windsor block. . Low speed velocity is a problem with the 4V heads. The ports are so huge that the intake flow is lazy at low RPM. Restrictor plates used to be available when this engine was commonly hot rodded. Running 4.56 gears helps this some. The best head for the street is the 2V head. These work well at all RPMs. |
That is an old-wives-tale from 35 years ago. Closed chamber heads with flat top pistons of reasonable compression increase the quench and increase detonation resistence. All the newer engines have strong quench for swirl. Personaly I would stick to the W series. Better W heads are available that makes the stock type C heads look poor. |
The best way (IMO) of building a CLEVOR is 4V (open) heads on a late (F4TE) 351W block. Use the 351C crank and adaptor plates to mount EFI.
Just like a sore chicken...You can't beat it...
