351 coleveland c4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2005, 11:25 AM
New Member
351 coleveland c4
i have a 351 cleveland and am rebuilding it possibly and hopefully around 400 hp i have a c4 and a guy who builds race trannys saying that he can build me a c4 that will withstand the power he can build it for me for about 650 bucks. i am wondering if this is a good price and if this trans will actually hold the power. he says ill have no problems with it. he says the c4 wont rob as much power as a c6 and its smaller just want some outside advice too see if this sounds reasonable. thanks alot
Old 08-22-2005, 11:53 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I like C6 better, but...
I like C6 better ... they're just beefier to start with.
I have read previous posts that do confirm that a well-built C4 will be OK, too.
$650 sounds fairly reasonable for a "race-prepared" transmission, at least in this area. Does that include a convertor (or at least a convertor flush)??? If not ... I'd recommend it.
Bottom Line:
I suppose that as long as the guy WARRANTIES the C4, I'd be willing to give it a try. Otherwise, I'd throw that cash into a C6.
Old 08-22-2005, 12:03 PM
New Member
it comes without a convertor. im going to send the trans tro him and install myself when its done but theres no convertor. i wanna be sure itll worrk before getting the work done
Old 08-22-2005, 01:40 PM
aka Duke of URL
Rule of thumb here;
The C4 can be modified to withstand about anything, is lighter and takes less power to turn. But on the other hand, a race-prepped C4 may not be able to withstand the rigors of everyday street driving. The C6 would be better suited for the street with the power potential of a modified 351C.
If you do use the C4, just make sure it has enough cooling and fluid capacity, especially with a high stall convertor.
351 Modified vs. 351 windsor vs. 351 cleavland ? Blackbob Engine 78 01-27-2013 05:15 AM
parts for 351 windsor Doug Renton Engine 5 09-13-2009 03:18 PM
Ford 351 Windsor Teardown & Rebuild 101 nightrain_rod Engine 10 07-20-2008 02:57 AM
351 Clevor vs. 351 Cleveland fearsomefairmont Engine 43 05-04-2008 06:37 PM
351 Ho? oldschoolrods Engine 17 03-05-2005 04:48 PM
