351 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2012, 02:26 AM
351 Ford
I am having an issue with my belts. I have a 68 351 W and I am no longer going to be using the power steering pump.
Originally I have the alt and the crankshaft in line with one another and running off the same belt.
Then we HAD the power steering pump and the water pump ( which has only one groove ) and the rear V on the crankshaft pulley working together.
At this point I have nothing driving the water pump.
I am guessing that the water pump may need a pulley with two grooves in it ?
Any ideas on what original application may have had this set-up.
I am not building a show vehicle. I am building a driver and am scrounging all of my parts through the local salvage yards.
Old 10-28-2012, 03:12 AM
Hopefully these picture will help
BTW the engine is a 1970 not a 68 if that makes any difference
ID:	68647   Click image for larger version
Old 10-28-2012, 06:10 AM
Irelands child's Avatar
There are sooooooo many combinations of Ford drive/accessory pulleys available that have been used - even on same model/year and with the same accessories that it would be almost impossible to "guess" what would work - and that vintage is right in the worst of Ford adventures with brackets and pulleys. The ONLY thing that will work will be a trip to a salvage yard, start looking at engines. You can use almost any Ford engine, but probably stay with 302/351s - as long as you have the right crank pulley - 3 or 4 bolt, depending on your particular engine (yep - been there with 351W Ford engines of that vintage)
Irelands child
Old 10-28-2012, 07:19 AM
Wiki Edits: 27
Ford accessory systems
Fords are a night mare , scrambled parts. When I was an engineer at Ford in California we used to have a lot of parts shortages during the winter months, the heavy snow in the Sierra Nevada mountains would stall freight trains, Trucks would try to use the shorter Route 80 instead of going thru Las Vegas.Sometimes the donnor pass would be closed to trucks and when opened again the trucks would have to chain up everything except the front tires. The Resident engineer in charge of power trains was always going thru the available inventory to find combinations that would work to keep the assembly line running.
Old 10-28-2012, 08:54 AM
I have been to the scrapyards, everything has been serpentine for a long time. I can google images of a 351 minus P.S and no A.C but not much info beyond that. Someone will hopefully have an application specific to what I am after
Scrapyards where I am crush everything after a few months so old stuff is not too be found
Old 10-28-2012, 10:39 AM
You're NOT HEARING US!!!
Fords of the '60s-'80s - close to impossible to tell anyone what year or model a set of brackets or pulleys will match up. Go back and reread my post then timothale's And those junk yards that crush cars, yeah, those are near me too - well you will have to find one that specializes in older cars - and those are usually not on main roads and often just a farm field full of their cast off junkers.
Irelands child
Old 10-28-2012, 01:54 PM
Im hearin you, eventually someone will come along and will read this post that maybe owns a 70 model ford somthinorother and it will not have P.S. on their car nor A.C and they will be able to help with some images/measurements and maybe some info on what I need to look out for.
Thanks for the tips though anyway
351 Modified vs. 351 windsor vs. 351 cleavland ? Blackbob Engine 78 01-27-2013 04:15 AM
Ford 351 M 1980 Rick Engine 4 02-22-2010 07:04 PM
Ford 351 flexplate on Ford 289 1931 steve Engine 6 11-06-2005 11:52 PM
Ford 351 37fordslantback Engine 3 04-25-2004 01:57 PM
ford 351 w/c carfreak17 Engine 16 05-12-2003 01:44 PM
