351 Modified Givin me trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2007, 11:46 PM
Hey Got a 351 Modified First I am not sure what the timing is for it (marine application) I can get it started after playin with it a little bit. Thinking I am close and the engine getting warm I cant get the dang thing to start back up. I have cleaned the carburator the engine cover is off so it gets planty of air. She just doesnt want to start up once she is warm. Any Ideas would be Helpfull.
Old 03-17-2007, 12:03 AM
kuhn-77's Avatar
Build it right the first time
try retarding the initial timing a little bit after warm and check to make sure the mechanical advance weights are not stuck also unplug your vacuum advance as well and try to start agan
Old 03-17-2007, 03:26 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
First determine if it's fuel or fire..
Spray a bunch of start fluid (carefully) Down the throat of the carb (Throttle open) and see if it fires..if it does..it's Fuel..Check your fuel pump pressure, filters and primary squirter's..
If it doesn't , pull a plug, get a jump start cable, clamp one end to the battery negative, the other around the plug base, plug the wire in, and crank, look for a BLUE spark..If not, check the dura spark box and/or module they could be going thermal and shutting down when warm..BE sure the block, dura spark box and battery are all on the same ground buss..(assuming this is in a wood or fibrglass boat..)
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
351 Modified vs. 351 windsor vs. 351 cleavland ? Blackbob Engine 78 01-27-2013 04:15 AM
The ford 351 modified bazerkmerc78 Engine 29 01-20-2011 10:30 AM
Original or Modified? 428ho Hotrodders' Lounge 22 01-20-2007 07:39 AM
351 Modified More Hp??????? zigz1981F250 Engine 5 07-17-2006 08:38 PM
351 Ho? oldschoolrods Engine 17 03-05-2005 03:48 PM
