351 w "tbird" valve covers - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2010, 08:44 PM
Does anyone make a valve cover for the 351 W that looks like the 312 T Bird covers? Or an adaptor to put the early covers on the later engine?
Old 08-19-2010, 09:54 AM
I know these aren't exactly 312 modled valve covers but take a look at these Homan Moody covers... probably not cheap but thought I would pass it along.
http://www.holmanmoody.com/parts1.html
(scroll down when clicking the link)
Old 08-19-2010, 12:16 PM
ericnova72's Avatar
More for Less Racer
I would have a hard time believing anybody makes these, no market for them and no profit to be had.
Old 08-19-2010, 12:24 PM
Irelands child's Avatar
I have a feeling that if they are anywhere close to the size and configuration of the 351W valve cover mounting surface (they really aren't! The 351W is trapezoidal and the 312 is rectangular) that you will have to make your own adapter. The 351W has 6 bolts directly into the head rocker surface while the 312 'Y' block has only 2 nuts in the top that originally were attached to the heads by a long stud from two of the rocker arm shaft stands. A Bridgeport mill and a drill press working on a piece of aluminum plate.........
Dave W
Old 08-19-2010, 08:20 PM
Thanks guys, I figured that was the answer. Are there any covers that look good without edelbrock, etc splattered all over them? Nice fined aluminum?
I'm a Chevy man but have a customwer that wants a 351 in a 56 wagon so I'm seeing whats available.
Old 08-19-2010, 10:31 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
http://www.speedwaymotors.com/Small-...vers,5480.html
http://www.speedwaymotors.com/Ford-R...vers,3223.html
Couple of options that might work for you..
Sam
Old 08-20-2010, 05:58 AM
...or if Billet Specialties still makes these (they're approx 2 years old and Summit supplied them ~$125). They are/were not well advertised by anyone. Matching air cleaner as well
Dave W
Builder says 1/4 more on rockers....HHHMMM? sooper Engine 29 07-16-2010 01:17 PM
David Vizard's Idea of Almost Bottoming Hyd. ? BUFFALOBILLPATRICK Engine 46 06-24-2010 02:25 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
center bolt valve covers jesse01 Engine 10 02-18-2005 07:50 PM
Tall valve covers needed? KeithB123 Engine 15 02-03-2004 12:54 AM
