351 windsor in a 49 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2005, 07:39 PM
jaxhome's Avatar
My buddy currently has a flathead 8 in his 49 ford. He wants to replace it with a 351 windsor. After pulling the flathead, it's looks like the 351 will hit the steering box. Will we have to replace the steering box, and if so, any suggestions? The front crossmember is staying stock except for a two inch spindle drop and disc brake conversion. Also, any advice on using a C4 or C6 tranny?
Old 03-29-2005, 07:46 PM
Max Keith's Avatar
351 in a 49
I cant address the steering box issue, but I would go with a good C-4, with a shift kit in it. The C-4 is plenty stout and a shift kit will cure all the minor ails.
Other advantages to the C-4, are lighter weight, and less perisitic hp loss through the tranmission.
Old 03-29-2005, 08:44 PM
aka Duke of URL
-289/302/351 Mounting Kit-
Old 03-30-2005, 07:24 AM
brainsboy's Avatar
brains
I'll add in that the C-4 is alot smaller and shorter then the C-6. For what your doing the C-4 should be enough, especially if your talking about a stock 351w.
The C-6 is a nice choice also. The clutches are bigger, and the internal parts are stronger. Yes it takes more power but if your not bracket racing and just a street car then thats ok. Very heavy duty and even in its stock form will outlast a built C-4. They are larger, heavier, and longer, but personally I feel they have 1/2 the problems that you might see with a C-4.
Either way, I would buy a junk C-6 and make it fit. The reason is lets say you build the car now for the C-4, then later you want to change to a C-6, it may not fit because of clearance problems. If your in the building process now, I suggest fitting a C-6 to start with, make your clearances around the bell housing, floor pans, once this is done, any other transmission will fit.
Ford 351 Windsor Teardown & Rebuild 101 nightrain_rod Engine 10 07-20-2008 02:57 AM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
ford 351 w/c carfreak17 Engine 16 05-12-2003 02:44 PM
Ford Straight 6 swap to a 302 or 351 BillyBob1950 Engine 5 01-18-2003 03:42 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
