#1
351 windsor conrod to conrod end float tolerance
Currentily building a 446 stroker windsor need a manual for engine specs for referancing for conrod end play to conrod on crank torqued to 40 ft/lbs but worried on tolerance between conrods using dart block eagle crank chevy 6.125 rods but rod are locking up probabliy need maching on trust edges on rods any susgestions.
Register now (free) or login to remove ads |
| Thread Tools | Search this Thread |
| Similar Threads for: "351 windsor conrod to conrod end float tolerance" | ||||
| tolerance in pully alignment | DaSouthWon | Engine | 8 | 12-17-2006 11:08 AM |
| 3/4 ton Chevy Semi Float to Full Float Swap | Rob Keller | Transmission - Rearend | 2 | 05-18-2006 12:23 PM |
| piston tolerance | Matts99Sierra | Engine | 4 | 01-30-2005 09:52 AM |
| LS1 block tolerance | Mad Maggot | Engine | 2 | 10-18-2004 08:18 PM |
| Cam Wear Tolerance? | 54 Chevy | Engine | 2 | 01-09-2003 12:30 PM |
