Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 351 Windsor into 1959 Ford Ranchwagon
Old 02-24-2013, 04:33 PM
JeffB's Avatar
JeffB JeffB is offline
Originally Posted by chrisfoster1959 View Post
I'm looking to put a 351 Windsor into a 1959 Ford Ranch Wagon.l'll need engine mounts.
Can anyone tell me where I can get engine mounts to suit
Also, what will I need to do with the rear cross member. Is the original easily adapted or do I need to get an adaptor of some sort?
It is currently a six cylinder, 3 speed manual
Thanks
Chris
Have you been following this post ? 59 Ford Motor Mounts The answers are there A better quality mount set USA made is these:
Energy Suspension 4.1124R Motor Mount and Transmission Set for Mustang : Amazon.com : Automotive Energy Suspension 4.1124R Motor Mount and Transmission Set for Mustang : Amazon.com : Automotive
these are used in 1986-93 Mustang 5.0's I would advise forgetting the C4 and use a 1988-93 5.0 and AOD as a donor as the AOD overdrive will play better with the 6 cyl geared rear end you can learn volumes about the AOD here: www.clickclickracing.com The 1988-93 AOD's have an improved valve body and lubrication upgrades and are still non-computer for an easier hookup.
The Following User Says Thank You to JeffB For This Useful Post:
chrisfoster1959 (02-25-2013)
