351 Windsor into 1959 Ford Ranchwagon - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2013, 11:56 PM
I'm looking to put a 351 Windsor into a 1959 Ford Ranch Wagon.l'll need engine mounts.
Can anyone tell me where I can get engine mounts to suit
Also, what will I need to do with the rear cross member. Is the original easily adapted or do I need to get an adaptor of some sort?
It is currently a six cylinder, 3 speed manual
Thanks
Chris
Old 02-24-2013, 09:04 AM
vinniekq2's Avatar
do you have a 351? can you weld?Are you staying with a standard transmission?Is the 6 cylinder engine dead? do you have any pictures of the car?
The Following User Says Thank You to vinniekq2 For This Useful Post:
chrisfoster1959 (02-25-2013)
Old 02-24-2013, 01:49 PM
I haven't purchased the 351 yet. Looking for a C4 auto as well.
I've not tried to start the car - it was purchased as a non runner.
I've attached a couple of photos
Old 02-24-2013, 01:52 PM
Another photo
Old 02-24-2013, 01:53 PM
And another photo
Old 02-24-2013, 01:55 PM
vinniekq2's Avatar
That looks like a great project,nice score.Maybe get the thing running if possible,fix glass and see what comes next.Just driving that car would be a rush,
Old 02-24-2013, 04:30 PM
I'm not positive about this but I'm pretty sure that Ford didn't change the full size frames very much between 57 and 64. The 63 and 64 models could be had with the 260 or 289 v8 motors. So you should be able to do this with factory mounts.
The Following User Says Thank You to hpete For This Useful Post:
Old 02-24-2013, 04:33 PM
JeffB's Avatar
Thanks
Chris
Have you been following this post ? 59 Ford Motor Mounts The answers are there A better quality mount set USA made is these:
Energy Suspension 4.1124R Motor Mount and Transmission Set for Mustang : Amazon.com : Automotive Energy Suspension 4.1124R Motor Mount and Transmission Set for Mustang : Amazon.com : Automotive
these are used in 1986-93 Mustang 5.0's I would advise forgetting the C4 and use a 1988-93 5.0 and AOD as a donor as the AOD overdrive will play better with the 6 cyl geared rear end you can learn volumes about the AOD here: www.clickclickracing.com The 1988-93 AOD's have an improved valve body and lubrication upgrades and are still non-computer for an easier hookup.
The Following User Says Thank You to JeffB For This Useful Post:
Old 02-24-2013, 04:34 PM
Wiki Edits: 27
59's info
Check out Jeffb's info about the other 59 today.
The Following User Says Thank You to timothale For This Useful Post:
Old 02-25-2013, 01:00 AM
Thanks JeffB
Will the AOD bolt straight up to the Windsor block?
Old 02-25-2013, 03:27 AM
AOD trans
I'm interested in the AOD trans option rather than C4. I've found one that supposed to fit a Cleveland. Will this bolt up to a Windsor with no modifications?
Thanks
Chris
Old 02-25-2013, 11:03 AM
JeffB's Avatar
Only use the donor AOD's I posted above the earlier versions are problematic and should not be used.
Old 02-25-2013, 11:39 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Actually a fellow can get on craigslist and find a late 351 with an AOD attached from a donor and transplant the thing hide fur feathers an all into the wagon without a great deal of difficulty and have the efi and all that..Look for pickups with 2wd when you are looking..and find a good runner..Much more economical to do it that way..
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
Old 02-25-2013, 01:53 PM
Thanks for all your help.
I am in Australia so I assume the AOD's put in local V8 Falcons from 88 to 93 would be the same as used in US Mustangs from the same era.
Are there any distinctive external features to look for in the correct AOD
Thanks
Chris
1959, fairlane, ford, ranch wagon, windsor
1973 Ford Windsor 351 Renegade Redneck Engine 1 08-20-2010 11:42 PM
Horsepower on ford 351 windSOR? Haulin327 Engine 2 10-10-2009 02:28 PM
Ford 351 windsor problem 77fordf100 Engine 2 10-07-2008 06:13 AM
351 windsor into 58' ford 55 dude General Rodding Tech 1 12-08-2007 07:39 PM
351 windsor in a 49 ford jaxhome Engine 3 03-30-2005 06:24 AM
