351 windsor into 58' ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2007, 03:35 PM
dudes! anyone here have any info on this swap. i have seen the "aftermarket bolt in kits" for $150+ but there has to be someone who has used 99% of off the shelf parts. it looks like 57'-59' fords are pretty much the same. if you have done one or helped chime in. thanks!
Old 12-08-2007, 07:39 PM
the mount mis-alignment is something i counted on. hoping to get someone feedback that has one or actually has done one. the mount that will be used is the "single stud" type the stock one (352) has "double studs" style. hoping someone had a spec on the adaptor piece they made for their swap. project has lots to do so any shortcuts would help.
Bagging a 58 Ford?? fastrehotrods Suspension - Brakes - Steering 2 05-19-2007 09:41 PM
351 windsor in a 49 ford jaxhome Engine 3 03-30-2005 06:24 AM
Ford 351 37fordslantback Engine 3 04-25-2004 01:57 PM
351 Best all around Ford Performance Motor? lakecityg Engine 28 07-25-2003 09:30 AM
1978 Ford 351 what's it worth jde68 Engine 1 07-18-2003 03:42 PM
