351 Windsor: minimum 350+/350+ with stock crank,rods and heads?
That's right. I'd like to get these numbers or better with stock heads, crank and rods. Have a D4 block that will be cleaned up, lined, bored, honed and decked. From what I've learned reading many threads the crank and truck rods can handle 500 with a good balance and assembly. The only reason I mention them is because I have no desire to go any combination of stroker so PLEASE don't even bring it up. I also don't want to spend money on a RETRO anything or increasing valve sizes. The stock heads will be ported and get a good valve job. Also I have some good roller tip 1.6 rockers I'll be using and a Eddy performer intake. (not an rpm. I know, but it was a freebie) Can someone fill in the blanks for a good flat tappet cam, carb (thinking a holley 600-650?)and piston. Any help is greatly appreciated.
Find some heads off of a torino, or something of that nature From 1974-69.
There are no exhaust humps, and you should easily make more power with no porting. Nice intake/cam/headers and you should be right at 350 no problem. Use craigslist. You should be able to find these relatively cheap. |
Anyone else? It seems that the biggest hurdle are the heads. I may be able to pick up a set of bare iron Trick flows for dirt cheap. NIB. 1.94 in. 1.60 ex. 68cc chambers. Under $300. Good deal? Any idea how much HP these could support? How about a cam/piston reccomendation. Not building a race car. Just want a solid reliable engine for a 2500 lb. Kit car.
Smog era heads and cams lie at the heart of the poor performance of those engines regardless of brand. Replacing them with modern well thought out heads alone are worth 40 to 60 HP. Put in a fairly mild cam of about 200 degrees and .45 inch lift and with a decent header exhaust and intake and you're looking at an easy 350 to 400 ponies without braking a sweat. Bogie Last edited by oldbogie; 07-20-2010 at 08:25 PM. |
| Stock 350 with 305 truck heads? | CrazyT | Engine | 3 | 08-04-2009 01:15 PM |
| SBC 305 Heads on a 350 ???? | Brawler | Engine | 9 | 01-06-2009 09:48 PM |
| Power gains on 454 with stock heads? | maddogg20 | Engine | 8 | 01-18-2008 06:06 PM |
| 350 heads | TTFiveOhRanger | Engine | 3 | 05-01-2007 10:42 PM |
| 350 heads or 305 H.O. heads????? | crshrmn3 | Engine | 3 | 08-25-2002 08:51 PM |
