351C 2v 71 Torino build
This might be redundent but here we go:
I bought a 71 Torino a couple years back, got it looking nice, put on a couple bolt on parts, fine. But its still an old tired dog. So now Im thinking of testing my hand at engine building. Any and all help would be great. Id like to keep the cost down and use as many parts that I've already purchased as possible which means Id like to keep it a 2v. Plus the torq is decent in a 2v. Here's what I got: C4 Trans Hooker headers 3" into a 3" exhaust dumped right before the rear axel. RPM Air Gap intake Edelbrock Thunder series 650cfm Im fairly certain it has the 9" rearend but Im not home to double check at the moment The plan is to build an engine and keep the current engine in and then do a swap. So far I know Id like throw on a pair of the aussie closed heads, and to keep cost down, probably the cast iron ones. Likely have it bored 30 over. Absolutely max money Id like to spend is $4000 to $5000 for everything including any stall converters, OD's, or changing the gear ratio. What would you do? Desired use is never taking it to a track, but maybe from one light to the next and being very fast. The car is only a weekend driver at best. I live in a high altitude (4,500 ft). I appreciate any responses. Thanks guys! |
here are some sites that have a lot of info on the cleveland that may help you:
Cleveland Forever's Home Page Mustangsandmore.com - The Online home for Ford lovers good luck with your project |
You say in your post you would like it to be fast light to light, but you also stated you wanted to keep it 2V. A 2 barrel carb is not going to compete well in stoplight races. You are simply limiting your power. Get a decent 4 barrel VS and it should be fine. Otherwise you are limiting what cam you can use heads etc. A 2V will not keep up with demands of modern cylinder heads that flow well. Otherwise just freshen up the old motor, keep the 2V and call it a day
| 351C build | madmaxx | Engine | 1 | 01-12-2013 08:46 AM |
| 351C build ?'s and input | voodoosurfer | Engine | 23 | 09-30-2011 01:47 PM |
| torino | SALLY | Introduce Yourself | 1 | 08-13-2007 10:44 AM |
| 69 Torino GT | anthonyc | General Rodding Tech | 1 | 12-14-2006 04:28 PM |
| Anyone build 351C 2V heads w/460 intake valve? | Aussie XAXB | Engine | 2 | 11-20-2005 07:56 PM |
