351C has bad miss at idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2005, 02:32 AM
Steve-0321's Avatar
1973 351C 2V motor.......stock cept for points ignition replaced with Pertronix electronic conversion.....the problem is that there is a miss at idle when the engine is cold but when its warmed up its not so aparent......i suspect something with the ignition coil........i tested to see what kind of spark i was getting and when i cranked it, only the first couple of sparks were blue like i heard they were supposed to be then they fade to orange sparks........is that correct and could that be the problem?
Old 04-29-2005, 04:28 AM
Last journal entry: Robs34 - Done my dash
Furses, coiled again !!
A 90Kilovolt spark will jump a half inch gap and be blue at the same time. The problem is likely the coil or polarity of the coil; the positive connects to the ignition switch and the amplifier of the ignition module and the negative goes to the dissy. Also check for good earth contact to the chassis from the engine and that the coil is matched to the high energy ignition, it needs to bea low impedance type.
Happy hunting
Rob
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
fast idle frydz1985 Engine 1 10-19-2004 11:12 AM
Need to fix my V6 daily driver's idle! 1meancuda Engine 6 11-12-2002 08:37 AM
High idle in my daily driver!!! 1meancuda Engine 9 02-19-2002 12:19 PM
