351C heads worth buying?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2008, 12:29 PM
for a ford man...
i have read that cleveland heads are hard to get a hold of and are nice to use on a 351w block.
are they worth buying and at what price???
thanks,
Old 09-17-2008, 02:45 PM
FASTFORD's Avatar
I think so, if you are referring to 4V closed chamber heads.
this is just MY OPINION.
if you already have Cleveland parts stashed & want to build a "C". building a Cleveland or a Clevor ( "C" heads on a Windsor) is a bit more expensive than building a Windsor.
the cost of "C" heads in good shape depends on the condition of stated parts & what has or has not been modified.
"C" heads on E-Bay seem to average in the 3 to 5 hundred dollar range. 2v heads will usually be less.
again, this is my opinion.
Old 09-17-2008, 04:20 PM
onebadmerc's Avatar
I need a bucket of arc sparks
351 C two barrel heads are not that hard to come by. You can find them on 351C, 351M and 400 engines which were made up into the early 80's. The open chamber four barrel heads are easier to find than the closed chamber versions, but they are still obtainable. The Australians made a closed chamber two barrel Cleveland head that that mixes the best from the two and four barrel Cleveland heads. Finding a good 351c block is alot harder since alot of them have been used up over the years. They quit making the 351c in the U.S. in 1974 but they continued its production in Australia into the 80's. The Australian 351C is alot better than the U.S. stuff, thicker castings with more nickle in their iron. If you want a 351C try look into using the Australian castings.
Old 09-17-2008, 06:55 PM
thanks
good info guys thanks a lot.
Are these heads worth anything? 48ChryslerRodder Engine 2 05-05-2007 05:16 PM
Options Options ffcagle34 Engine 7 08-17-2006 05:20 PM
Anyone build 351C 2V heads w/460 intake valve? Aussie XAXB Engine 2 11-20-2005 08:56 PM
sbc heads Jared Engine 7 03-03-2003 08:07 PM
L98 IROC/TA/Formula heads? dirtlmfan Engine 2 02-17-2003 01:02 PM
