has anyone tried to put a 351c into a 66 stang. will it fit and who has the headers. I have just about finished all the mechanical on the car,(9in rear and 4wheel disk w/hydroboost.) i have just finished the 351 and c6, and want to make sure it will go in and still be able to change plugs.(and yes it is a (C) not an (M).... thanks
Yes I have a 351W in my 65 GT 350 clone, It's a W but should still be close. The major thing will be the header/steering box area, Use short straight headers. Downside is the last two plugs on that side can only be pulled with headers removed, at least that is what I have found. I have all the 289 emblems as well as the air cleaner on her, Give away is when you see how close the motor is to the shock towers, Hauls *** .
i had a 69 elimininator- had a 428cj-i broke the plugs loose with a socket then either used vacume hose or garden hose to spin them out-on the passenger side i had to take the front wheel off to get access to the last to to the back-it will fit-it will be tight-back then you couldnt get headers to fit because of the shock towers-but i still ran 12:88@125mph in the quarter--good lucknull
Hello, I am 45 and going to college and about the biggestgearhead is one of my instructers, ebryant@crowdercollege.net, hope and know he will help, Patch
Yes the 351c will fit in your mustang but one of the head bolts on the right bank will hit the shock tower under hard acceleration. I have found there are two alternatives they are two alter your shock tower, or the best way is to run solid motor mounts.
Good Luck Longtexan38 |
years ago I built an international pickup with a fullhouse chevy 350 and under hard acceleration it would break the welds on the left motor mount,I cured the problem with a turn buckle and chain from the left front of engine to the frame...just a suggestion
