351C randomly shutting off.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2006, 12:05 PM
Steve-0321's Avatar
ok so i dont know whats goin on now. I was on my way to work this morning and i was taking a turn and the motor just turns off. I try to get it started again but it didnt start for like 5 minutes. I made sure fuel was getting to where it was supposed to be and i checked to see if my coil was firing. Check. Could this be the distributor? or possibly a bad ignition switch? i have no clue. anyone with anything to say will be greatly appreciated. Thanks
351C 2V
Stock distributor with Pertronix module
initial timing set to 10 btc(6 is stock)
Old 03-09-2006, 12:17 PM
Max Keith's Avatar
engine stops running
IF you have another coil you can put on your engine, try it. Sounds like your coil is getting hot and loses its ability to create juice.
Old 03-09-2006, 01:06 PM
97Z28's Avatar
NTI Grad.
it could also be the ignition module getting hot and causing the problems. because it will cause the same symtoms as your describing.
Old 03-09-2006, 01:07 PM
Steve-0321's Avatar
im not sure if thats the case but ill try...the thing is the car wasnt even warmed up all the way when this started.....and the coil is even mounted away from anything that gives off heat
Old 03-09-2006, 04:42 PM
aka Duke of URL
To eliminate the PERTRONIX module, install the points and coil and see how she runs.
What year and carburetor?
Old 03-29-2006, 03:04 PM
JVunk's Avatar
I had a similar problem in my 70 Torino. It ended up being the distributer bushings were wore out. I changed it out and never had another problem.
ford 351C aussie heads? bob myers Engine 5 01-09-2006 10:15 PM
351C needs help fast PlEASE! Steve-0321 Engine 6 11-23-2004 11:42 AM
351C Questions Psychobilly79 Hotrodders' Lounge 5 08-27-2004 01:51 PM
351w, 351c, and 351m intake manifolds El Retardo Engine 4 08-08-2003 09:41 PM
351c ID MarcR Engine 1 11-04-2002 03:13 AM
