351c thing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2002, 07:43 AM
Post 351c thing?
Hi guys,right i"ve got this ranchero 1971,first v8 ford i"ve ever had(i"m into chevys)Anyhow i ordered a edelbrock inlet manifold + holley 600vcfor it.I took the old cast manifold off to get the job ready for when my new gear arrives ok.
now the old inlet manifold gasket is like a thin steel tray,is this factory ? It"s got me wondering,because when i ordered the new edelbrock inlet i said to the bloke "does it come with new gaskets,or do i have to order them,He said he"ll have a look + if not he"ll throw in some?" QUESTION IS "do i need the tray type or will the long thin 4 port&gt;&gt;one each side do the job? H.K. your brain rreQ....phil <img src="confused.gif" border="0">
Old 10-08-2002, 08:12 AM
aka Duke of URL
Arrow
[quote]...the old inlet manifold gasket is like a thin steel tray, is this factory ?
QUESTION IS "do i need the tray type or will the long thin 4 port&gt;&gt;one each side do the job?<hr></blockquote>
Yes...It was factory installation on the Cleveland. It keeps oil from splashing out of the lifter valley and hardening on the underside of the intake, causing heat absorbtion into the intake charge.
Are the heads 2V or 4V as the replacement will be different for each one. FEL-PRO is a source for the valley pan gasket.
A regular set will work but oil residue will collect on the underside. If the guy promised this to you...Hold Him To It!
They are fairly expensive.
Old 10-08-2002, 08:14 AM
aka Duke of URL
Red face
Oh...
How impolite of me...
Give my regards to the Queen...
Old 10-08-2002, 08:19 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
It's called a valley pan. It's original use was to shield the intake from the hot engine oil from the bottom of the intake. Hopefully this would lower intake charge temps, making more power. The problem is they don't seal very well on modified intakes, Milled heads, or other mods that change the angles of the head in relationship to the blocks deck surface. Use the "4 hole, one for each side" gasket. It's easier and you'll be happier with it in the long run. If you get worried about the intake charge temps than you can coat the bottom of the intake with silicone gasket maker to help insulate the manfold runners but make SURE that its COMPLETELY! dry before assembly.
Old 10-08-2002, 08:21 AM
Post
Damn KULTULZ, you beat to the reply!
Old 10-08-2002, 08:23 AM
Post
HI KOOLTOOLS,YEH should have said the heads are 2v
the only other motor i"ve seen with this gasket set up (that i"ve had) is the Rover (buick)stuff,I think i better phone de man + make sure , cheers tulz,
Old 10-08-2002, 08:24 AM
aka Duke of URL
Cool
johnsongrass1 posted October 08, 2002 10:21 AM
[quote]Damn KULTULZ, you beat to the reply!<hr></blockquote>
heh...heh...heh...
[ October 08, 2002: Message edited by: KULTULZ ]</p>
Old 10-08-2002, 08:31 AM
Post
THE QUEEN SAY"S F**K YOU! "she"s a bit of a snob normally"
AND to the guy on dope (JONSONGRASS1)sorry i sort of typed over ya while you where tryin to put ya 2cents <img src="graemlins/pimp.gif" border="0" alt="[pimp]" /> cheers 2ya2......phil
Old 10-08-2002, 08:52 AM
aka Duke of URL
Exclamation
Well...If that is the attitude she is going to take...Tell her I will have to cancel Sunday tea...You know how it is in the colonies...
I am just kidding you know...
You guys are OK...all but the warm beer...
Old 10-08-2002, 07:27 PM
woodz428's Avatar
Troll Hunter
Post
2bbls and 4bbls came with this setup and the regular gaskets seal better than the metal tray. But you should cut the tray part from the intake sealing area and keep the oil baffle plate to keep intake manifold temps down, you can re-use it again and again by just replacinging the gaskets between the heads and manifold.
Old 10-09-2002, 09:05 AM
Post
CHEERS lads ,KULTULS QUEEN SAID "arise SIR KULTULS
OF THE ROYAL PRINCIPALITY OF ROCKVILLE"
CHEERS WOODS428
Old 10-09-2002, 10:06 AM
Post
All Right now, Just to clear the air of all this SMOKE,(used to think that was a bad thing lol) I am proud to state That I've been clean for 5 years! Now just to get rid of the damn nickname, it just kinda stuck ya know!
