351M to 351C - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2003, 11:47 AM
fordzilla502's Avatar
Angry 351M to 351C
Hi this is my first post hope it's no too long.I have a 1979 F-150 4x4 with a 351 Modified in it. I would be sticking a "hotter-cammed" 351 Cleveland in it except for flywheel problems... cannot locate 351C flywheel. Please direct me to the nearest cliff or directory. Thank you.
Old 03-15-2003, 03:55 PM
aka Duke of URL
Question
Standard or automatic trans? And if A/T, what model.
Old 03-16-2003, 06:24 AM
Post
I have a manual transmission. I am hoping that a flywheel off of a 302 will be ok (balance-wise) on a 351 Cleveland.
Old 03-16-2003, 02:16 PM
aka Duke of URL
Arrow
I just did some looking in the MPC (Master Parts Catalog) and a service replaacement flywheel for the 351C 4V is D7TZ 6375-C. Go to the 302 in the CAR and then to the LIGHT TRUCK section and it is also calling for a D7TZ 6375-C (BRONCO-FAIRLANE POLICE-PICKUP). So a certain 302 flywheel will interchange according to FORD so the CLEVELAND must have the same imbalance as the early 302.
It gives casting I.D.'s of C7TE-A and D7TE-GA even though I am sure there are more but not listed in the service parts catalog.
So as long as you have the same diameter and ring gear count they should be interchangeable.
If the above fails;
<a href="http://www.mrgasket.com/haysindex.html" target="_blank">-Hays Clutches-</a>
