Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 351M Cam Questions
Old 12-02-2012, 11:19 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
If it needs a new timing chain go for that..what I have had success with is to advance the timing to 9/10 degrees at idle..the carb may be an issue as it may be fat on the idle mixture which will cause some loading issues..try the simple stuff first..
Sam
