Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 351M, does it fit?
Old 07-31-2008, 06:13 AM
Luiz's Avatar
Luiz Luiz is offline
ChevyNut
Originally Posted by Silver Shaddow
Yup, the 400M truck motor also uses the Ford big block bolt pattern.
I think you are right, a standard passenger car Cleveland or Windsor engine would be better, and I believe both also have a higher compression ratio and rated horsepower than the "M" truck motors.
Not withstanding that probably the M engine parts are more expensive.
