Don't know about the engine mounts, but the bellhousing to engine block bolt pattern is different. The "M" series engines used the Ford big block bolt pattern which is different to the normal 351/302 Windsor and 351/302 Cleveland small block bolt pattern.
Yup, the 400M truck motor also uses the Ford big block bolt pattern.
I think you are right, a standard passenger car Cleveland or Windsor engine would be better, and I believe both also have a higher compression ratio and rated horsepower than the "M" truck motors. |
A 351M/400 uses different motor mount placement as well as the BB bellhousing...Learned that one the hard way when I used a 351 cleveland for mocking up my motor mounts in a 54 Ford pickup that was going to get a 400 installed.
Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| Recent General Rodding Tech posts with photos |
| 351m questions | elvisjer | Engine | 15 | 12-23-2008 09:08 PM |
| What crank ect will fit on a 283 SB | chlsnk | Engine | 12 | 06-18-2008 05:39 PM |
| Will any of these intake fit? | TekeTorvo | Engine | 13 | 05-29-2008 11:04 PM |
| 460 vs 351m | "70" Cougar | Engine | 11 | 02-17-2008 04:17 PM |
| will a 351 fit in ranchero? | aaronv8 | Engine | 5 | 01-31-2004 10:39 AM |
