Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 351m questions
Thread: 351m questions
Old 03-07-2008, 07:52 PM
RicklesPickles RicklesPickles is offline
351m question
I was in your same boat when I put a 351W in my 73 mach1 that had a 351C in it. the 351C and 351M share the same exhaust port flanges but the 351W uses the standard SBF exhaust port flanges(bolts are straight across on both sides of port, the 351C has staggered bolts ala BBC) also note the 351M has a BBF bolt pattern so you cannot swap transmissions over. If you have the trans from the 351M great, if not you have to find one that was on a 351M/400M/460/429.
Anything that fit on a 289/302/5.0/351W and 351C will work with the Windsor.
