351m timing help any addvice help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2008, 09:47 PM
hello all.
im new to this so bear with me.
i have a 351m.
the guy i got the motor from passed on.
he pulled it down to put a new cam in and never got it done.
i put the cam and new timing set in it.
now i need help setting the distributer.
it does not have a timing pointer tab. so i want to get it right the first time. i dont want to have to pull a plug and bring it back up to tdc that way.
i dont no where the #1 sets on these things.
ive never set a distributer on 1 of these. do you no a site that i can go to so i can see where the bug points on the cap and see where the vac advance sets when you drop it in to line every thing up.
thanks a bunch.
Old 06-10-2008, 07:12 AM
Greg T's Avatar
www.krusinklassics.net
In the time it took you to post this you could have had it done. Put your #1 on TDC compression stroke, drop the dist in the hole and wherever the rotor points will be your #1 on the cap. Continue around for your proper firing order. Fire it up and set the total timing.
Old 06-10-2008, 10:03 AM
timing
it may have been an odd question, but i like do get things done right the first time. it should be ready to drop in now since i put the new chain in and the motor has not been turned over right.
how do you no when its on the compression stroke if you did'nt no 4 sure
thanks
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 04:26 PM
Timing problem - Help MTMike Engine 1 11-13-2002 01:07 PM
