351w>393 stroker kit on gas - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2011, 06:01 AM
Is it possible to run a 351w>393 stroker on gas/petrol.
Old 12-24-2011, 08:30 AM
68NovaSS's Avatar
Wiki Edits: 9
Depends entirely on the build, c.r., cam specs, etc., give up more information.
Old 12-24-2011, 12:32 PM
Last journal entry: update
Petrol? Where are you, Europe?
The Ford 351W engine was designed for American gasoline. It can be converted to run on compressed natural gas, or liquified propane gas. LPG conversions can be done in such a way that you can switch to gasoline, or back to propane, with a toggle switch added to the dash.
Stroking a 351W to 393 doesn't change any of that. It gives you more torque, and a bit more fuel consumption under most conditions.
Gasoline doesn't like as much compression as the gaseous fuels, but building a nice compromise can be done on a tight budget.
Ford 347 stroker vs 351W Augusto Engine 12 12-13-2011 07:37 PM
351w stroker aaronv8 Engine 19 12-24-2010 09:37 AM
ford 347 stroker vs 351W Dubz Engine 12 07-07-2010 08:16 AM
351w stroker BadMonkey Engine 5 08-09-2009 12:54 AM
351W Stroker mattoxcw Engine 9 01-21-2004 07:46 AM
