351W and 5.8L the Same? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2007, 08:03 PM
Last journal entry: Sweet Looking Dash
Is a Ford 5.8L and a 351W the same block and bolt patterns? Meaning, the Bell Housings, Water Pumps, Oil Pans, Heads and motor mounts are all the same?
I have been debating between a small block Chevy and a 351W for my 37 Ford Coupe and want to be sure if I pick up a block that has plenty of aftermarket parts available.
Also: Will a 5.0L T5 Tranny, Bellhousing and clutch bolt up and work fine on a 351W? Do I need to worry about correct weighted Flywheel? If so which Flywheel weight would be correct for a 351W? Is the 164 Tooth flywheel the way to go or are their other options?
Thanks for the Help
Clark
Old 10-22-2007, 08:05 PM
Wiki Edits: 31
yes, there the same
yes to the T5
28oz flywheel
Old 10-22-2007, 10:25 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I'm a Chevy guy but a Ford definitely belongs with a Ford engine. Stick that 351W in there. That's all the advice I can give you on this one.
Old 10-23-2007, 08:54 AM
I'm really glad to hear somebody feel this way.
351W blocks are basically the same but there are differences. The early blocks were stronger but the first two years had a shorter deck height (.020" shorter I believe) which could leave the piston coming out over the top of the deck a little bit. They are still sought after because of their strength. I don't know when but the 351W went from a 2 piece rear main seal to a 1 piece. The last 351W blocks were made so that they could use a roller cam but I'm not sure of which years. Maybe somebody else will chime in that knows the specific years.
Danny
Old 10-24-2007, 12:45 AM
aka Duke of URL
YOU'RE GLAD!?
Late production 1983
1994- F4TE (Roller Block)
Rough Idle while warming up 351W Vac. Advance Mustang67in209 Engine 7 12-03-2006 06:08 PM
5.8L timing chain mowerman Engine 1 07-25-2006 08:26 PM
