351w exhaust manifold/header fitment question in 73 Mach 1? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2007, 08:44 PM
Hello,
I have recently put a 351W into my 73 mach 1 and im needing information on what kind of exhaust manifolds will fit with 351w and C6 trans. Will truck manifolds work and clear the steering box that is below the 8th cylinder and kinda tight. I had a 351c in it and i obviously cant use the same manifolds. Any experience with this combo please help out.appreciate it
thanks
Pickles
Old 12-27-2007, 07:22 AM
onebadmerc's Avatar
I need a bucket of arc sparks
The truck manifolds are different than car manifolds, you will need to find a set off a 351W car. You can also use 302 car manifolds but they are a little bit smaller and won't flow as much. If you want headers here is a set for your car.
http://store.summitracing.com/partde...5&autoview=sku
Exhaust tips CrazyRoyExhaustfreak Engine 0 10-29-2006 06:04 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Custom Exhaust Question / Help KevNJ Engine 7 03-30-2003 07:37 AM
another exhaust question chevyman17 Hotrodders' Lounge 0 03-14-2003 10:18 AM
75 Jag with Corvette 350 exhaust question Jag Daddy Engine 4 03-12-2003 03:30 AM
