351w heads c9oe vs gt40 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2013, 02:26 PM
Just wondering if anyone knows the differace and witch would be better for my 351w build, i have the c9oe heads on there now, but found some gt40 heads down the street, for $100.00..
I have basicly stock bottom end, with a lumpy cam, edlbrock performer manifold, 750 dp, msd ignition, and open exhaust,,,
its in a boat,,,any thoughts would be great,,,,thanks
Old 03-07-2013, 05:01 PM
JeffB's Avatar
You would probably be better off keeping what you have or saving up for aftermarket aluminum heads,302/5.0 heads have 7/16" head bolts your 351W has 1/2" bolts so you would have to redrill the 5.0 heads whereas the aftermarket heads are always 1/2" so when using them on a 302/5.0 they require special head bolts or sleeves.
swapping 351W heads for 302 heads babell7738 Engine 10 01-21-2012 10:16 AM
Machining requirements for cam with GT40 heads KMatch Engine 3 04-05-2010 06:33 PM
GT40 Heads? octanejunkie Engine 6 01-20-2010 04:55 AM
gt40 vs. gt40p vs. e street heads 72fordlb Engine 3 06-15-2009 06:27 AM
GT40 heads FoxThunder 5.0 Engine 1 07-30-2003 02:11 AM
