Thread Tools Search this Thread share on Facebook
  #1
Old 05-06-2005, 11:00 PM
smitty299 smitty299 is offline
351w off idle stumble maby ????
hi guys i'm having trouble with my 351w it has what i think is an off idle stumble. its a stock motor with 70000km with a holley model 4160 carb i have read posts about changing the booster pump cams and nozzle's witch made no difference at all i tried disconecting egr valve changing from ported to manifold vac advance changed plugs and wires dis cap and rotor button, nothing i did made anny diff. i'll try to explain what the car is doing when i step on the gas it starts to go then stumbles then takes off the lower the rpm the worse the stumble it will even do this while i'm doing 140 km hr on the highway if i back off on the gas and then back on it although recovery time from the stumble is quite noticably shorter. i've also set the timing according to spec. any help would be greatly apreciated as i have no idea what to try next
Register now (free) or login to remove ads
Old 05-07-2005, 01:02 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Last journal entry: '59 El Camino gas filler door stops
Wiki Edits: 21
Is you accelerator pump arm set tight as it should be? There should be zero slack between the arm and the pump actuating lever. Even the slightest movement of the throttle should squirt gas into the primaries. Also, what secondary diaphragm spring are you using? Might try stiffer springs to delay the opening of the secondaries. If they are opening too soon, air flow velocity goes to zero, killing the signal to the booster venturies and killing gasoline flow.
Old 05-07-2005, 04:23 AM
carl01's Avatar
carl01 carl01 is offline
fords rule
my 351w did the same thing and i took my holley off and put an edelbrock intake and 850 on it and it straightened right out now i made my 351 into a 426 stroker with dual holley 450s it pushes about 650 hp
Old 05-07-2005, 05:50 AM
the pump arm is set proper and i went from a purple secondary spring to a plain steel one anny more ideas ??
Old 05-07-2005, 07:57 AM
lluciano77's Avatar
lluciano77 lluciano77 is offline
Short changed on common sense
It is only a problem in the acclerator pump circuit if it is immediately out of idle. If it occurs above that it is probably an incorrect powervalve or a timing issue.
Check your float levels again.
Set your mixture using a vacuum guage. Take the highest reading from the guage while the car is in park if auto, or in neutral if manual. Divide this number by 2 and add .5. 16" divided by 2 is 8 + .5 = and 8.5 powervalve.
Get an advance analyzing timing light and figure out exactly what your timing curve is. Without knowing that it is pointless to try and tune the carb or anything for that matter.
Old 05-07-2005, 10:48 PM
thanks 77 i will try the timing i changed the powervalve to the correct size and set the mixture screws with a vacuum gauge. when i put the carb on the motor i checked the timing it was 9 deg btc and i set it to the factory recomended 12 deg btc and come to think of it thats when i started having the trouble. i'm glad someone mentioned something other than the carb i was getting ready to throw it away i've been over it several times and everything about the carb seems as it should. i'll play with the timing and post a reply i hope it does the trick
Old 05-13-2005, 05:55 AM
fixed it put a new edelbrock model 1405 on it runs like new
Old 05-13-2005, 06:53 AM
KULTULZ KULTULZ is offline
aka Duke of URL
Well...You narrowed it down to a carburetor problem...
That is after determing there is a .015" clearance between the actuating lever and accelerator pump lever at WOT, correct?
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "351w off idle stumble maby ????"
ThreadThread StarterForumRepliesLast Post
I'm going to make a bonfire out of my carblown69stangEngine3608-22-2005 03:36 PM
Off idle stumbleAngliaBobEngine1603-27-2005 05:31 PM
off idle tip in stumble6speedwagonEngine207-27-2004 09:47 AM
Stumble off idle in park, carb or ignition problemDubzEngine305-18-2004 10:29 PM
427 4bbl. off idle stumbleanglia48Engine510-18-2003 03:37 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
