Thread Tools Search this Thread share on Facebook
  #1
Old 01-24-2009, 03:27 PM
ntx_gearhead ntx_gearhead is offline
Last journal entry: Well, about that mustang...
351W pistons?
Hey guys,
I'm looking at dropping a 351W into my 66' Mustang and I'd like to know what's the largest bore I can realistically use on that size block? Also, what manufacturer pistons would you recommend? Thanks
-Gearhead
"Drive It Like Ya Stole It"
Register now (free) or login to remove ads
Old 01-27-2009, 12:50 PM
ScoTFrenzel ScoTFrenzel is offline
Originally Posted by ntx_gearhead
Hey guys,
-Gearhead
Lot's of them 60 over at 4.060 inches= 362.5 cubes
A few thousandths means little to power. I suggest your staying as small as possible.
I recommend a forged piston, of the new alloys.
Pick a brand you can afford, but I say stick with forged, and the new modern rings.
Try SpeedPro.
Measure your deck height and seek for .040 minimum -.050 maximum, and adjust by getting the proper thickness head gasket unless you are prepared to mill the block deck to zero.
Old 01-27-2009, 06:47 PM
Thanks for the response. I was under the impression that the larger the piston the more HP. Maybe I'm missing something. I've checked out summitracing for the pistons and I agree with using SpeedPro. They seem to be the reasonably priced and they have a good reputation from what I'm hearing. As far as the deck hgt... if i had the deck milled to zero what kind of head gasket would I need? Thanks.
-Gearhead
Try SpeedPro.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "351W pistons?"
ThreadThread StarterForumRepliesLast Post
need help with blower pistonsmalibu68Engine301-19-2007 10:32 PM
Blower pistonsmalibu68Engine1512-14-2006 08:49 PM
pistonsjerry1Engine512-14-2006 10:19 AM
Pistons were made wrongbrainsboyEngine103-04-2004 05:00 PM
Long skirt SBC pistonsfierosumEngine901-16-2004 07:02 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
