351w pushrod length - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2012, 12:54 PM
351w pushrod length
I have a standard deck height block and with a set of Procomp 210 heads. The cam is a Comp XE274 flat tappet with Comp 1.6 roller rockers. I have read that these heads will require a longer pushrod than normal. Anyone have a length recommendation or will the advertised Comp pushrods work? Thanks!
Old 04-13-2012, 06:31 PM
LATECH's Avatar
You can buy or make a push rod length checker , which is just an adjustable pushrod.
Look around the engine section and search - pushrod length and also valve train geometry and also mid lift geometry. there is a ton of info there.
With those aftermarket heads you may be able to get a good geometry at
Mid lift. Thats a good thing. Also it explains a lot about losing lift due to bad geometry and deflection.
Old 04-14-2012, 07:04 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 on the length checker.
Cole
Old 04-14-2012, 09:13 AM
Appreciate the info guys. Will look into it.
Pushrod length??? 71chevy Engine 7 04-02-2009 12:08 PM
pushrod length? metalamn Engine 6 11-21-2006 12:30 AM
Pushrod Length ProjectSuperNova Engine 5 02-16-2005 11:22 AM
Pushrod length? Trav Engine 2 10-07-2003 10:50 PM
pushrod length kellogs Engine 4 01-12-2003 03:30 PM
