351W Rear main seal... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2007, 09:21 PM
301Customs's Avatar
I have an engine rebuild kit for a 1987 351W.
In the kit there is a one piece rear main seal with a valley on one side and flat on the other. I assume the valley goes towards the engine and the flat side towards the tranny. Can anyone confirm this. I have never swaped out a rear main seal before.
Also, the package came with about 12-16 of this little round rubber things. Never seen them before. Can anyone tell me what they are used for?
Thanks!
Dave
Old 04-15-2007, 05:45 AM
aka Duke of URL
Yes. If one has a spring in it also, the spring will go towards the lubricant. There is a special service tool that makes installation of these much more precise.
Valve stem seals?
Old 04-16-2007, 02:20 PM
301Customs's Avatar
Thanks...
Thanks for the input.
Actually it slid right on, no problem.
I thought the valley should face the block. Just wanted to make sure.
You were right about the other rubber pieces.
Thanks again!
Dave
Old 04-16-2007, 02:48 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
They may just be keepers or 'bungs' to keep the gasket in place - keep it from moving around on the pan lip? My guess.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
55 chevy, 265 rear main seal slingslingbinks Engine 5 10-19-2004 09:27 AM
Oil Leak. Rear Main Seal?? 7skylark6 Engine 6 04-27-2004 03:20 PM
Rear Main Seal Silentlion_69 Engine 5 12-06-2003 06:34 PM
rear main seal in 350 bstm23 Engine 4 12-02-2003 12:57 PM
