351W roller rocker/valve cover problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2012, 09:24 AM
Putt's Avatar
I have a 351W Ford that I have installed World Windsor Jr. heads and roller rockers on. I checked and ordered the correct length pushrods (it also has a Comp retrofit hydraulic roller camshaft) and I would like to install the valve covers that are World Man-O-War tall chrome covers. The baffle in the cover hit the Poly-locks! I have cut out the baffle, thinking I would fab a small plate or use baffled grommets for the breather and PCV valve. The baffled grommets also hit the locks and hit the rocker arms too!
How much of a plate do I need for a baffle or how have any of you solved this issue?
Old 09-15-2012, 10:46 AM
Irelands child's Avatar
Use double gaskets, a spacer or even taller valve covers - you need the baffles pretty much full size, particularly the PCV or you WILL suck oil into the carb/engine via that PCV. Already 'visited' that situation with a very healthy 351W a good many years ago.
Irelands child
Old 09-15-2012, 03:14 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
On my BBC in the T-Bucket, I used a one inch spacer, it was so thick I had some of my rockers hitting on the top side, had to relieve them a little bit for clearance. How much room do you need? Maybe a double gasket will work for you too.
Semper Fi
Old 09-16-2012, 08:09 AM
Putt's Avatar
I need 1/2" to 3/4" of an inch and I am not sure at this time if I can raise the valve covers that much. The engine is going in a 1965 Mustang and those cowl braces are really close o the valve covers. I am going to set the engine in and see what I have for clearance. Thanks for the info.
Roller rocker problem Curtis Thornton Engine 10 05-19-2009 12:44 PM
Scorpion Roller Rocker Problem 4onthefloor 2 Engine 5 12-07-2004 07:47 PM
rocker arm taps valve cover Echofive Engine 3 11-22-2003 05:15 PM
roller rocker and valve cover clearance 56madmook Engine 5 03-24-2003 02:53 AM
PONTIAC ROLLER ROCKER/CAM 455 VALVE ADJUSTING trannsientorca Engine 2 11-10-2002 09:13 AM
