Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 351W SBF rookie build
Old 11-14-2012, 10:30 AM
celamb89 celamb89 is offline
Hi everyone,
After several years of having the project stopped due to several problems I picked up the '71 mustang project... I'm now rebuilding the 351w sbf and have a couple of questions, hopefully some of you can chime in...
My dad purchased some parts several years ago, since he passed away I picked up where he left off... The motor is currently being taken apart and the time to acquire the needed parts is approaching...
Current parts:
1x Chet herbert Solid Roller camshaft (.510 lift x 240 duration)
1x Set of solid roller vertical bar lifters
1x true roller timing chain
1x set of KB Performance Pistons, Piston Dia.: 4.030'', Flat Top, 2-Valve Reliefs, Neutral
1x set of Moly rings
1x set of 350 open pressure vale springs
Ported cast heads
1x set of chrome moly 5/16 Std. Ford 351w
1x set of 1.6, 3/8 SBF Magnum Roller Rockers
1x set of mahle strengthen guide plates
1x edelbrock RPM air gap intake manifold
1x edelbrock 750cfm carb
Any tips, sugestions, comments are more than welcome... The car will be a street performance car, I want to be able to drive it around but pack a punch.... The other idea was stroking it to a 393... I would love to cut some costs, Im currently paying my college loan and Im pretty short...
