Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 351W SBF rookie build
Old 11-15-2012, 07:13 AM
celamb89 celamb89 is offline
You're right it is a big can for a beginner hopefully with all the help Ill be able to make the right calls.
Steel Roller rockers are 167 which isn't to bad, since the cam is a high lift high rol as you said hcompton I believe they are going in.. But breaking the motor in with the stock 1.5 sounds good then I can drop the rollers in...
