Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 351W SBF rookie build
Old 11-15-2012, 08:19 AM
celamb89 celamb89 is offline
Originally Posted by Irelands child View Post
Be REAL careful with any lift over ~.510 on a Ford, especially with stock type heads. A .604 lift WILL NOT work without being very careful in your piston selection.
Oh and the stock rocker arms are 1.6, not 1.5 with 1.7 being the option.
You have no gain by using steel roller tip rockers which retain the sliding fulcrum. You may also get into push rod length problems whereas the standard sliding tip aren't so fussy as to where they land on the valve tip
What piston Would you recommend? Would kb hypers work? Or by piston selection do you mean triple measure everything?
I was also looking in to the aluminum scorpion roller rockers, I'll see what u can work in tote budget. I might break the project in 2, first build the inside then et the manifold, carb and headers. That will give me some breading time.
