Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 351W SBF rookie build
  #17 (permalink)
Old 11-15-2012, 06:13 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by Irelands child View Post
You have no gain by using steel roller tip rockers which retain the sliding fulcrum. You may also get into push rod length problems whereas the standard sliding tip aren't so fussy as to where they land on the valve tip
Times 10,000.....thank you.
