Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 351W SBF rookie build
  #29 (permalink)
Old 12-11-2012, 12:12 PM
celamb89 celamb89 is offline
choosing the right heads
Hi everyone,
Im back with my head spinning around choosing the right set of heads for the setup...
The intake manifold is going to be a Ford Racing Dual plane 1500-6500RPM...
Looking around I have it down to 3 options:
Dart 13211112 - Dart SB-Ford Pro 1 Aluminum
  • Intake Ports: 195cc
  • Combustion Chambers: 62cc
  • Valves: 2.02" Int/1.60" Exh
  • Intake Port Location: Stock
  • Intake Port Dimensions: 2.000" x 1.125"
  • Intake Flow: 288 cfm @ .700" lift/28"
  • Exhaust Port Location: Raised .135"
  • Exhaust Port Dimensions: 1.350" x 1.350"
  • Exhaust Flow: 185 cfm @ .700" lift/28"
Dart 13111182 - Dart SB-Ford Pro 1 Aluminum
  • Intake Ports: 170cc
  • Valves: 1.94" Int/1.60" Exh
  • Intake Port Dimensions: 1.980" x 1.100"
  • Intake Flow: 261 cfm @ .600" lift/28"
  • Exhaust Port Dimensions: 1.330" x 1.340"
  • Exhaust Flow: 172 cfm @ .600" lift/28"
AFR - Airflow Research 1399 - AFR SB-Ford Outlaw Street/Race Aluminum
  • Combustion Chambers: 58cc
  • 165cc Intake Ports
  • Intake Valve, 1.900'' Stud Mount
  • Exhaust Valve, 1.600'' Stud Mount 58cc
What would you recommend? I have doubts regarding the Intake ports (cc), combustion chamber (cc for compression reasons) and quality DART vs AFR ?
